MK2 RS2000 Story so far
    Stunning job
      Looks good...who did you use to rechrome your headlamp reflectors? They look a good job.
        Thanks for the comments Carlo / Andy
        Ashford Chroming did the headlights, if you aren't in a hurry great as they were away for nearly 2 months so they must be kept busy
          Car out for the first time this year, shame, still not under under her own steam
          Time to trial fit the engine into the bay so I can get the wiring loom finished and fuel lines cut to size so here goes
          First, manifold fitted
          Now to get it into the bay
          Right at home
          Happy now as I having looking at for months. Next bit was to get some of the engine parts and washer bottle of for dipping
          Well that's it for a while so back into the corner of the garage till next time
            Coming along very nicely Donnie. When will you have it up to THE Island
              She will be up next year so be will over for a ceilidh and looking forward to seeing your one
                Any time Donnie
                  Not a lot has happened in the last year or so due to work commitments so little update from where we left off;
                  Wasn’t happy with the rechromed inner headlights and luckily a set of New Old stock were sourced in Sunderland, what a gent and great price so not everybody is out to make as much money as possible and keep escort parts at escort prices rather than some of the inflated prices we see nowadays but that’s what you have to pay if you want it
                  Headlight backing plates removed once again
                  Headlights now in place on the backing plates
                  Finally happy with the lights
                  Now to fit the fuel pump / filter assembly with the boot floor marked ready for drilling
                  Pump now installed
                  Time to start making up some hoses
                  Tank and pump now connected
                  Now fuel regulator to the rail
                  Return was not so simple at first as the straight fitting on the rail was too close to the bulkhead
                  Quick change of fitting, that’s better
                  Return will have to wait till next week, honest will update again next weekend
                    looking good but suction pipe from tank through the spring isnt a good idea ?
                      Need to have another look at it when I am back, that’s her jacked up on the axle so leaf spring will lift a little bit more but not expecting that much more but more as she is close enough to the bump stop as she is
                        You needn’t fit a return to the rear of the fuel rail, you could of fitted a single feed with a “T” piece on the supply and blanked the rear rail.
                          It was set up without a return on the focus but it was chucking flames out the exhaust so hopefully this will cure it
                            Fuel line rerouted :-)
                              Out n the sun, just need to refit the interior now
                              Interior now being reinstated
                              Taking shape
                              Nearly done
                                Looks Great
