Escort Mk1
  • Passenger Side Arch Fitted
    • Some great work going in there.. Blink and it'll be painted
      • Originally posted by LOUIE View Post
        Hopefully painted before Christmas!
        • More work to the passenger side -
          Even using the wider ex-pressed steel arch - there is a gap which will need to be filled
          Tub repair
          • Tubs fitted
            • Spare wheel trough and Fuel Tank trough
              Spare wheel retaining strap bracket - mounted to the boot floor
              • To give an idea of just how bad the previous repairs were - here is the patch work quilt that made up the wheel arches!!
                • marzipan
                  • Naughty that. Somebody needs a smacked behind for repairs like that
                    • Originally posted by rwdrs View Post
                      Shot at dawn would be more appropriate!!
                      • Dashboard
                        The replacement six dial dash is installed
                        • Bulkhead Corners
                          The finish on the bulkhead corners wasn't the greatest
                          So a small skim of filler is applied
                          • Comment
                            • Rear Scuttle Panel
                              As with most of this car - has been previously repaired badly
                              The entire rear bulkhead, parcel shelf and rear scuttle are going to be replaced with a cut from the donor car
                              Unfortunately it's not going to be as easy as just weld in the replacement panel - as the inner scuttle has some rust
                              • So the repair will involve the best parts of both panels and a new fabricated inner scuttle panel.
                                The old scuttle panel is removed
                                Exposing the inner scuttle
                                Another pile of scrap!!
