Out of disaster comes ...more bloody work
  • Cheers mike
    First job on todays list was to cut the gear stick hole
    Then set the height i want the gear box to sit.
    Once i put the mounts up on the tunnel i found that there was a bit of a gap
    So i decided that it would be easier to cut and extend the bolt on mount to suit
    Then all was ok
    • As of tomorrow i shall be ordering the rollcage from custom cages
      • Very good move!!
        • I work just around the corner from Custom Cages, they had a really nice looking Mk2 Escort in there the other day.
          • Started to clean off the inside of the roof skin today so i can paint it before the cage gets here. Once i got the remnents of the sound proofing off the ammount of rust was a shock. I ended up shot blasting the entire inside of the roof
            Then instantly sprayed it with oxide primer
            • Woohoo its ready to be posted
              • Originally posted by Mikethepanel View Post
                Thats some exhaust mate !
                • Originally posted by lee bishop View Post
                  Those pipes look like they should be attached to an organ
                  You could probably play a tune if they were used as an exhaust!!!
                    Its got to be that long for noise regs
                    • little of that i know, but wouldn't it be an idea to double plate that each side ? gonna take a lot of stress and vibration in its life however good your welding is ............. just a thought
                      • Originally posted by grum View Post
                        I have used thicker steel than the original mount is made from
                        • its more the "weld" than the thickness of the metal ...... just a double precaution .................. oh how we'll laugh at the first gearbox mount broken retirement ........ no malice intended
                          • Heres the cage weld test ready to go back to custom cages as the first part of the FIA/MSA certificate
                            • What sort of lead time do you get with Custom Cages? Are they pretty quick to turn things around?
                              • Originally posted by havard01 View Post
                                It took about two and a half weeks from ordering to it being delivered
