My Mk1 Escort 1300 Sport Project
    Did a little bit on the sport over the weekend, made a start stripping it down..
    took rear seats & parcel shelf out..
      and stripped out the glass & mechanisms out of both doors, took heater & wiper motor out.
      its had replacement doors fitted in the past..
        floors under rear seats look good,
        took old headlining out, nice original paint behind it.
        thats all for now.
          nice to see a update m8.
            Bit of an update, been taking more bits off the sport over the weekend,
            radiator out & exhaust off,
            took servo off & pedal box out,
              wiring loom is in a bit of a mess!
              some rust to be sorted out under the heater bubble,
                found part of the hole that rev counter fitted into before the dash had been cut,
                another pic of the floor,
                I've splashed out and ordered half floor pans from expressed panels so i can cut all this out & do it properly.
                  Looking good mate
                    thats all for now.
                    Very nice shell, good to see paint on roof under headlining, mines just surface rust and no top coat!
                    will make a cracking motor.
                    keep up the good work.
                      bit of an update, got the engine & gearbox out,
                      a few dents on bulkhead to sort out,
                      removed engine bay loom,
                        couple more pics of the strut tops, this lot will need cutting out & doing again.
                        thats all for now
                          Looks a great base mate, look forward to seeing her progress
                            So much better when it is all stripped out, you can see what's what! Usual places that rust but nothing that can't be put back to it's former glory! Lovely resto this!
                            Tim
                              Excellent project.
                              Good luck with it also.
                              Wanted one of these since I read the article in Street Machine on Ron Harris and his son.
                                Thankyou for all the comments! I've started buying some bits for it & managed to get hold of an original set of moulded rubber mats which it would have had when new, they've got a couple of splits & a bit grubby but should clean up ok, I'm pleased with them though as they're so hard to find now .
