platers
  • platers
    anyone recommend a company to do plating of small parts like door catches , bonnet catches etc ?
    Glasgow chromers near ibrox done all my stuff from my Mk2 escort, great job
      They quoted £600 to do a bumper ! Gtf
        Try Derby Plating, I have just had a few things done with them. They only charged £430 for Mk 1 Escort Rear Bumper . Scary the prices these places charge.
        Derby Plating : 01332 382 408
        Thanks
        Richard
          Ever thought about the DIY plating kits - ideal for smaller items you mention?
          Check out our range of metal plating kits. Save on cost, not on quality.
            yes i did look at these , anyone used them?
              Yep I bought a kit and yep it works alright.
              I disposed of the chemicals in the end, not great to have the stuff lying around, what with the pickling solution and all, but yes I even managed to do a bonnet stay. If it is costing silly money and you only have small items that will fit in the buckets you get then fine, otherwise, just get a firm to do it.
              The trouble is of course that you can't really put a big batch of gear in any single coating operation, so to get a large volume done it'll take a lot of goes. It can also be a bit or miss, as the voltage passing through the solution varies a lot and the more you passivate, the longer it takes to get a coating of zinc on the parts…
                I also bought a kit and I agree with all of the above.
                  Interesting, I was contemplating getting a kit, what power source did you guy use?
                  As you say all the videos of "diy kits" show only a few parts at one time , all hanging individually.
                  How do the big companies do batches of bolts etc? do they use a rotating mesh bucket or something?
                  Robert
