My White Car
    I've recently bought a new one it's rubbish.
      The engine bay is joy fella...... Not!!
      I'm looking forward to starting my interior, clean work
      Getting bored with the idiots
        good to see u getting time to work on ur car alan.
        cracken wae the carpet idear there .
          Nice day in Cumbria and so spent a couple of hours on the car ,,
          Fit the seats back in and a new set of belts
          On reflection I should have gone for blue belts ,,,,, also added a little motiff to the seats
          Next bits.. a new steering wheel new rear mount lucus reverse lamp and a set of cibies
            Think I need to change those belts for blue ones ,,
              i see your door caps are now black and dash silver do you not like the look of wood pack ? Carpet does look the business Martin
                You mean black......
                  Dident have a wood dash so I wnt for the silver facia with the wood,,, I have now got hold of a full set of caps so need to rub then down and restain and varnish them
                  The ones I had were from here and there and never stained up correctly and were completly different grains and also the rear were split ,,, so the black was really an experiment to see how they look
                    Narr,,, blue like the side stripes ,,
                      Looking good Alan, nowt wrong with red belts, gives a bit of contrast, patriotic as well.
                      Gone to the Dark Side but still lurking!
                        Looking well alan.......when you said industrial size washing machine on the carpet did you use a steam cleaner?
                          It was actually down a local whirly wash ,,,,, threw it into the big machine that they use for soiled coveralls,,,,,,,,Refit to the car and used a couple of cans od carpet dye spray
                            Needs a nice mk1 centre console rather than the mk2 Ghia/sport one
                              Do they still fit due to the fact the gearstick hole has been moved back ?
                                The correct centre console fits like a glove. The gear stick hole is moved back as standard on mk1 rs2000's. so, will fit yours if moved back
