Basket case?
  • Cheers boys comments always appreciated
    • Your doing a top job mate
      Keep at it!
      • should be ready for the tour next year!
        Too old of a to be F**ked by kittens
        • Originally posted by paul spence View Post
          • very good
            • Stunning Work....
              Andy
              • Nice work Daz
                Proper rallying is done down the lanes!
                • good work Daz
                  • Top job. Is it a standard grinder with cutting disc you're using to cut out the steel?
                    Murdo DA
                    • Originally posted by murdo View Post
                      Cheers Boys for all your comments!
                      Yes Murdo standard grinder with 1mm thick cutting discs
                      • lovely job your doing there
                        following the thread from the start it looked like you needed a little guidance but you have obviously found your feet as your doing a cracking job with some very lovely welding, looking foward to the finished job
                        • Good job
                          Keep going mate. Some hard graft bein put in there. I see a Clarke 100E welder in a couple of the photos. Is that what you've been using all the time on this car? As im looking for a replacement welder myself and am impressed with the welds you've been putting down there.
                          • Originally posted by willypiper View Post
                            Hi Willy,
                            Yeah, thats the only welder i have used, had it years well paid for itself small torch as well to get into tight corners don't bother with the small bottles from Machine mart, get a gas bottle convertor and buy the large bottles of gas, as its the same price as buying three small bottles.
                            • Cheers mate. Il look into getting one. Not looking to put alot of money into a mig just now, and they seem quite cheap and by looking at your welds they look spot on. If i can get them half as as good as that il be chuffed. 0.5 wire you using ?
                              • wats thee up to lark,looks lark thes gettin ther now lad
                                few ard trannys for thee to practice thy welding skills on here?
