my first mk2
  • Originally posted by 13sport View Post
    How many rounds of ammunition does that gun fire then?
    Tim
    • Did a bit of test fitting today need to fettle the servo tower a bit more to fit the manifold not sure of what to do on this just yet
      Sat engine etc in place to check clearances
      Migh not be to everyone's taste but I like it!!
      • you should try fitting the clutch cable not much room their with that manifold
        • Will do cheers for that info
          • cracken update there m8.fair comeing together now
            nice to see a mock up going on
            dav
            • definitely steaming into the lead now!!
              Rik
              • [QUOTE=13sport;657948]Eventually got the rubber sealer sprayed on today, quite happy should look really nice with a coat of paint
                Please, what make of sealer did you use?
                • Wurth not that cheap at £10 a tube need about 14 tubes by the time you cover backs of the wings etc but makes a very nice finish and has good protection and sound deadening qualities
                    Thanks for that. I was spoilt with Wurth products when my son worked for them, but the products would be hard to beat in quality.
                    • Well its been a long time coming but I have started to make progress again all be it quite small. Numerous body specialists didn't seem to want to entertain the car so decided just to do it myself panel at a time even if it does take me ages so started on the rear panel as there are a lot of shapes in it that needed sorting out. Few hours of filler work Sunday and primered and guide coated tonight. Probably do Inside the boot area next then work my way forward. Planning to get the car in primer then leave it to sink and settle for a couple of months before block sanding.
                      Hopefully plenty more progress over the next few weeks
                      • You learnt to fit and repair panels mate so you'll do this ok .
                        I need to get mine started ASAP just need a garage building first
                        • I can already do it Carl but I'm not as good as a professional would be that's the problem
                          • You know you can do it mate, be great to see it done.
                            • Well a little more steady progress, front panel now all in primer, it annoys me how ripely the new panels are, although this was a really quite a good fit it was for from straight so it ended up have a full skim of fine filler to get the part below the grill nice and straight. Anyway quicj quirt of guide coat and its another panel ticked off the list.
                              Then back onto the bootlid. It was absolutely 100% rust free but wasnt flat so there was only one thing for it...a big fine skim of filler. I bought one of those flexible long blocks which has worked brilliantly. Just need to coat it with dolphin glaze then it will be ready for primer.
                              I've been using upol fantastic filler and I must say that's its realy nice to work with in comparison to the easy1 shite the sell. Blocks lovely with 80 grit then guide coat and remove 80 marks with 180 before primer.
                              Will probably jump onto the roof next then bonnet which thankfully doesn't need any filler!
                              • Bootlid now finished and primed, its another one ticked off the list.
                                Time to start mixing filler again now : (
