Rallye Sport Escorts - Home of
The fun, friendly and informative forum for all AVO & RS MKI & MkII Escorts
Go Back   Rallye Sport Escorts - Home of "The Works Team" - Ford - Escort - MKI - MKII - RS - AVO - RS1600 - Twincam - Mexico - RS Mexico - RS1800 - RS2000 > Main Forum > Basket Case's, Restoration's and Ongoing Projects
Reply
Thread Tools Display Modes
  #481
Old 31-07-2010, 11:17
ASHLEY's Avatar
ASHLEY ASHLEY is offline
Gameroom cash: $4810
Default
Stick at it m8 nice job
  #482
Old 31-07-2010, 11:24
DazRS2K's Avatar
DazRS2K DazRS2K is offline
Gameroom cash: $4670
Default
Quote:
Originally Posted by RUDDY View Post
See ya again in 18 months Des, no need to rush at it son !
Don't want to rush things son, you make mistakes doing that
  #483
Old 31-07-2010, 11:26
DazRS2K's Avatar
Default
Quote:
Cheers Mate i'll try lol
  #484
Old 31-07-2010, 19:54
bluevan1 bluevan1 is offline
Gameroom cash: $5380
Default some job
great work there m8.
looks a good shell to work with........
__________________
Dav
  #485
Old 31-07-2010, 20:29
DazRS2K's Avatar
Default Today's graft
Hi, well been cracking on today with a few more jobs. Need to get the inner in so I prepared the chassis leg as holes needed welding up due to removing the old one.
Welds were ground back and some Kurust applied to protect the metal as the inner wing leg slips over the top. Whilst the metal was curing, i moved to the passenger floor well, to cut out some areas I wasn't happy with. This area was directly above the chassis leg as you can see.
Next a patch was made with holes so I could plug weld ontop of the chassis prior to welding fully up.
Ground back.
Also cut this out and replaced.
All this area now prepped for the seat cross member to go back in. Thats the next job, then the biggy which i'm dreading the inner wing, need to prob measure loads to get it hopefully right, any advice, tips fitting this will be gladly received .
Well thats all for now friends, beer time
  #486
Old 31-07-2010, 20:33
DazRS2K's Avatar
Default
Oops fogot to add the last pic long day
  #487
Old 31-07-2010, 20:34
wetandwindy2's Avatar
wetandwindy2 wetandwindy2 is offline
Gameroom cash: $6048
Default
nice bit welding ,getting there
  #488
Old 14-08-2010, 12:47
DazRS2K's Avatar
Default Last weekend graft
Hi All,
With the help of Mr Spence, we mocked up the inner wing, AGAIN (See last year's post lol)
Once the panels were lined up, self tappers were put in to hold in place, this is for fine adjustment when the measuring process begins.
clamps removed. Wings were dropped on just to get an idea.
Well, the next job i'm doing is welding in the seat cross member on the passenger side and that's all the work finished in that area. I will post the pics soon. After that I will start measuring up to finally weld in the inner, then front and slam panel to get the front end finished.
Cheers Daz
  #489
Old 15-08-2010, 13:18
Default hi
looking well m8.
keep up the good work....
__________________
Dav
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Get Your Own Real Time Visitor Map!
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
